Good news about my transmission
  • Good news about my transmission
    So today I set out to rebuild the controled couple hydramatic transmission from my 57 Eureka. When I got the engine running last fall, the transmission had a terrible leak. Transmission fluid POURED out of the starter hole and flywheel cover. So I saved up and bought a rebuild kit while I pulled the transmission. On the torus (kind of like a torque converter) there was a "58" written in yellow greasepen, so I figured some work was done on the transmission, but the leak still existed. This is probably why the car sat for nearly 40 years. After removing the flywheel and torus cover, I found the torus seal was brittle, cracked, and in no way would prevent fluid. This is where the leak was. I went further into the transmission and found all the seals like new, the transmission was completely rebuilt. Here's what I think happened. When you get a rebuild kit for that year a car, it doesn't come with a torus cover seal. It just comes with the internal transmission seals. The only way to get that seal included with your rebuild kit is to ask for it. I'm guessing a shop (or person) rebuilt the transmission, but didn't think or know to order the torus seal. Even after the rebuild, the transmission still leaked and the car was parked. I'll know for sure as the weather gets better as I plan on putting the transmission back.
    Then I'll need to:
    fabricate or find some sort of gas tank or fuel cell
    fuel lines
    brakes
    drivers floor
    exhaust
    After that she'll be on the road, but the interior will totally need to be re done. Getting her on the road is a big deal tho. After that I'll do a little at a time till she's done.
    pics??????
      Originally posted by mdeanr View Post
      pics??????
        Of the transmission or the car?
            very nice car...........how's the engine run?
              flat top pistons, I think its 10:1 motor. Its VERY strong. Loud too, it doesnt have much exhaust.
              I'll have to look around, my buddy has a video of it running on his cellphone. We were pouring gas down the throat of the carb to hear it run. I know that's not the best thing to do to an engine, but I have redneck tendancies.
                i have a 1958 cadillac M-M limo-style that needs the 365 rebuilt.
                  Pics????
                  The more I work on these 365s, the more I really like them. They are strong engines.
                    Wait till all the lifter rods bend...
                      Originally posted by spastic_chicken View Post
                      Pics????
                      come to GA and rebuild mine!!! lol i wish i had the $ to have someone build it. the block needs to be sent to the machine shop.
                        Even with new lifters and pushrods?? Please explain...
                          i'm running a 1977 425 in my 58 at the momment.
                            I've seen a few rednecks set their engine compartments on fire that way. You should have at least the bottom part of the air cleaner on.
                              I'm not that dangerous, yes the bottom of the air cleaner assembly was on, and fire extinguishers were also in hand.
