I do believe these would eliminate that f'n smog pump!
Pulleys!
I just put those exact ones on my hearses engine, they are 1 inch in diameter smaller & half the weight.Last edited by kaptinkaos; 12-23-2008, 09:56 AM.
All you need is a 425 lower pulley. They have a groove that comes out forward far enough that you can put the belt around the crank, water pump and alternator, and eliminate the need to have the alternator driven by the smog pump. This is for single-belt systems, I think it's 1974 and newer.
Those are pretty, though.
-dee
