If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You may have to register
before you can post: click the register link above to proceed. To start viewing messages,
select the forum that you want to visit from the selection below.
You aren't smoking crack (unless of course you are smoking crack, in which case you are in fact smoking crack but exhibiting none of the normal symptoms) - I can't get the search index to rebuild for old threads, so it's only indexing things that have been created since the upgrade.
