1968 pontiac ambulance
  • 1968 pontiac ambulance
    I need to buy new tires for my 1968 pontiac ambulance. 235 75 15 probably but do I need 6 ply or what
    Other tires have you guys used. Another question. My Motorola generator alternator is not working anyone had tis problem and how did you fix it. I've been told do a one wire alternator..help!!
    You don't need 6 ply! Go with E rated truck radial tires.
      Standard 1 wire (GM) alternators from your local parts depots will work if you have a single battery. I would go no less than a 65 amp. The part - http://www.summitracing.com/parts/pwm-7102?seid=srese1
      Does it have DUAL batteries? If so, this is the best bang for the buck and I have yet to have issues out them. http://www.summitracing.com/parts/pwm-47294?seid=srese1&gclid=CPSV-KbWmbcCFZJj7AoddhQAHg
      H
      owever the second one that I recommended for the DUAL batteries will definately work for the single battery setup. Just know that the coach when in operation will not ever starve for juice. If you have lights & siren GO WITH THE BIGGER OF THE 2!
        Thank you!
          If your coach still has lighting and possibly a mechanical siren, you will need a LARGE alternator. 1 Wire as prescribed. http://www.summitracing.com/parts/pw...FQ9eQgodKmYAlQ This is a definate if you also have dual batteries!
            I tried posting a couple of times the help on the alternator. I guess since I provided links to the parts I was MODERATED..... WTH? Come on and approve the post so this man gets some help! LOL
