I have hidden rust I can not really get to easily with sand paper... how can I get rid of it? Sand blast it and then paint on some rust converter stuff?
I have rust hidden in between the layers of the hood and some on the INSIDE rear of the car
I took off the inside rear panels and found some crazy stuff near the seams of the top and the rest of the body. The stuff on/ inbetween the seam I don't think even a sandblaster can get to.... what do I do?
Also I don't want to bondo any of it. I want to get leaded body solder if I can find it cheap.
*update Below*
I got something called Naval Jelly Rust Dissolver to try out as well as Jasco Prep & Primer
I cleaned off some of the rust bubbles and flakes and loose rust then tried to sand what I could but the surface is too uneven to sand. I painted it with the Jasco Prep & primer. That is why it looks the way it does. BUT what do I do about all the areas I can't reach into and sand?
More pix here http://tiny.cc/73Hearse
*update Below*
