I'm need of a pad for my gurney. Does anyone know where i might find a cheap one fairly local? I see them on eBay for about $100 but it's the $50 shipping that gets me.
Stretcher or gurney pad wanted
If you know anyone that does sewing (doesnt have to be perfect or expensive seamstress)....you can make a cheap pad by getting a camping foam mattress (I used the thicker type for mine) and a shower curtain. The shower curtain should be the cloth type and its already fluid proof to an extent. We recovered all the cot pads at the Funeral Home that way a few years ago with a solid blue---it was very inexpensive and looked like professionally done.
I just used the foam and found a new zippered cot cover on ebay. Just cut the foam to fit and zip it up. It was vinal so I guess it's made to be wiped off.
We didn't use anything for support. Only covering the foam as the cot has the metal supports across plus our gurney has a head elevator to prop the patient at an angle--so if used any rigid support over the foam---that would not work so well.
