Today I got the roof painted it's final color..so it's done..The body will have to live in epoxy primer till spring..which will happen this coming thursday..Why spring?? because I still have wiring and other things to do..and that mean pulling the fenders off and I don't want to deal with fresh paint while wiring!GEDC0210.jpgGEDC0207.jpgGEDC0197.jpgGEDC0193.jpgGEDC0180.jpg and winters here are too nasty to paint!
1974 cadillac miller meteor build 10/9/11
Senior Member
- Oct 2008
- 657
NOLAhearse's totally amateur web mistress
1995 Buick Roadmaster Hearse (Eagle)--Shiny and pretty much stock
1986 Caddy Fleetwood Hearse (Miller-Meteor)--Phantasm tribute/Used body part distribution
1984 Caddy Fleetwood Commercial Chassis Hearse (Superior)--Zombie assault vehicle
I never had a vinyl top on this car so rust was not bad..I smoothed it out and sprayed an epoxy primer..then sprayed a sandable primer filler..blocked it out and shot it with a ppg single stage gloss black! My back still aches..but she's worth it! I used por-15 on the new floor inside ..I strongly recommend it for killing rust..it's hard as nails ..impossible to scratch (I did scratch it..but it took a portable band saw!)Originally posted by bluke1 View Postwhat did you use? i just finished sanding down my '76 M&M to get rid of rust, then painting with por-15. after a little bondo i was going to use a roll-on bedliner to hopefully prevent rust from ever returning.
Senior Member
- Jul 2008
- 949
Don't interrupt me while I'm talking to myself.
MOLON LABE!!!
http://www.6-ft-under.com
https://www.facebook.com/ReapersRides
The cheap bedliners will let water in. I had a friend put a cheap bedliner on her and in less than a week it was rusting under. I have Line-x on the top of my hearse. Most people don't know it's bedliner. My hearse had the crinkle top, so there was only slight rust.Originally posted by bluke1 View Postwhat did you use? i just finished sanding down my '76 M&M to get rid of rust, then painting with por-15. after a little bondo i was going to use a roll-on bedliner to hopefully prevent rust from ever returning.
