Factory auto leveling air ride hasn't worked in the time I've had my car. Guessing it developed a leak, which caused the compressor to stay on all the time, cooked the compressor. Factory shocks seem to operate up to 150psi, gabriel "hijackers" go up to 200psi so I wanted to put together something cheap & simple that could handle that if I ever needed them in the future. Cheapest on board compressor I could find aftermarket that is rated for 200psi is the Viair 380C, so I got one of those. Then I had to find an air pressure gauge, and went with the Viair 90090 [0-220psi, 2" black face single needle]. Just about all the other air pressure gauges I was finding only went to like 100psi.
Hardest part was finding the right compression fittings. Factory shocks use 1/8 hose, and the fittings/hardware used from the factory is cheap push together plastic stuff that really does not inspire any kind of confidence. For now I am going to cut the 1/4 hose off the back of the manual fill valve, put a 1/4 NPT compression fitting on it and plumb it in that way. If the plastic factory fittings & 1/8 hose end up leaking badly I will have to go get NPT compression fittings for them. Don't want to do that, because it seems like no one uses NPT fittings for 1/8" airline so they're a bit pricier.
Electrically I am just going to use a SPST to trigger a relay to control the compressor. This will assume that anyone who ever puts air in the car knows what they're doing and watches the needle on the gauge to turn the compressor off when it reaches the appropriate psi. Already needed to mount a SPST for the reverse camera [its not wired to the reverse light like it "should" be] so I made a quick bracket:
Bolts into where the ash tray would go and is completely reversible. Forgot that this gets rid of the cig lighter socket, so I will wire one up in the glovebox in case I ever need to plug something in [that's where the USB port for the radio is anyway].
Doesn't look too bad. Still need to run a 2-4 ga cable to the compressor under the table, wire up the relay, mount the compressor under there. I've only run the hose for the gauge so far, still waiting on the 1/8 NPT male for 1/4 hose compression fitting.
Do I really need to have an air release solenoid? I have a hard time imagining why I'd want to let air out of the system intentionally.
Might eliminate the hose on the right of my diagram, fitting EDD-166440 & one of the 92837 fittings and simply screw the T fitting directly into the air compressor. Part No. 92842 is simply an adapter so that if I ever go to a bigger air compressor I don't have to change much.
I like the viair fittings, since they're two piece fittings where the hose slips over a nipple & then the bolt clamps down on it. I really don't care for those disk-shaped "crush" 3-piece compression fittings and always seem to destroy the first crush disk and need to go buy more. Someone should tell the engineers at AutoMeter about that. A tool to make it easier to slide hose or line over nipple fittings would be nice too, but google says there is no such thing?
