Help needed
  • Ambulanced
    replied
    I think you have to push back the trim ring and there should be a roll pin at the base of the handle to tap out. I want to say that it is a square shaft that is pinned to the handle but I'm not sure. Good to see you fired up on the 49 again.
  • LMS
    started a topic Help needed
    Help needed
    So I am messing with the 49 today, all inspired after Asheville and shit, and I can not for the life of me figure out how to remove the window and door handles on the inside of the door. I know it will end up being some simple thing, but it has me boggled at the moment.
    These are the little buggers causing me grief.
    Help me Obi Wan Kenobi your my only hope.
