Well, I tested my aux power system. I was installing a small window unit air conditioner in the house, and I temporarily ran a cord out to the hearse and plugged it in. It only read 25% on my AC power meter, and I ran it for an hour or so. Batteries are still up. The A/C will have to cycle, but that shouldn't be any problem at night, in the shade. It may even get too cold in there.
If I did my math right, I have 3.2 kWH of AC available, minus whatever DC I use. I'm using 270 amp-hours of deep-cycle marine batteries, separated from the main bus by a camper diode, and also with a bus tie solenoid so that I can stop charging the batteries if my alternator is getting milked. I'm using three solar chargers to keep the batteries up while the hearse is parked for a long time.
If I can get the money together, I have plans to put an air conditioner in the hearse. The hot side will go inside the fenderwell. A fan will force air into the fenderwell from inside the hearse, and the air will exit down at the bottom of the coach, where the rust hole is now. This means that I don't have to fix the rust hole, just cut out the rusted metal and install a grille.
Heat is much easier. You just use a space heater.
