Couldnt find the old post of what you are doing to your ride.
Been very busy. Picked up a 63 Cad parts car. Been stripping parts, ebaying them and storing some also. Finished putting the front of the motor back on the 63 MM. Has todrill & tap 3 bolts going into the front of the motor. Fires up now. After a nameless asshole stole my money, I had to pull the other leaf spring assembly off to take to a shop to have 2 sets made. Very expensive. They will be finished on Monday. Drained the gas tank, and put new rubber fuel lines in. Found out the gas gauge worked, so now I have 6 gallons of bad gas. The tank is in good shape, but dented up on the bottom. Will probably put a bigger tankon sometime later. Rebuilt the carb, but have not installed it yet. Picked up a master cylinder, brake shoes, wheel cylinder kits. Have to change the rear axle brake lines, as they are damaged. Still lots of work to do till i can drive her.
