Does anyone out there know of any Air ride kits for the older hearses? I went to our local Air Ride dealer and they told me they would just use the universal kit with a few more hardware items.
Air bags
Originally posted by jason_sps View PostDoes anyone out there know of any Air ride kits for the older hearses? I went to our local Air Ride dealer and they told me they would just use the universal kit with a few more hardware items.
A good place to buy parts is www.suicidedoors.com . They can even fabricate brackets for you if you figure out what you need. There is also a lot of good information on their site about how to incorporate an air suspension into your vehicle.
www.airridetechnologies.com and www.airliftcompany.com or www.easystreetair.com are also good resources. typically their prices are higher on just about everything, but they do a lot of research and can really help you get set up with the right stuff if you're not mechanically inclined.
It's relatively strait forward. The only thing is if it's anything like mine, it was super tight to get it all to fit and not have to cut the floor. Luckly you'll probably be keeping your leaf springs, (which is way easier) instead of building all new control arms and mounts to get it to lay flat on the ground like me.
I've bagged well over 100 cars over the years, and there is nothing like draggin body and frame at 60 mph down the freeway and throwing 60 feet of sparks out the back, lol.
I used Air Ride Technologies AirOverLeaf brackets on the back of my GMC, and they have worked out well. If you have leaf springs, you remove all the leafs but one or two on each side, and the air bag replaces the load carrying capacity. The remaining leaf is used to locate the axle and keep it in place. I've been running it for 2 years with no problems. I did run two bags on each side in the rear for extra weight carrying capacity. Probably not necessary, but good piece of mind. I would definitely do it on a hearse since it probably weighs a good ton or two more.
I agree the front is probably the same as a standard Cadillac of the same year, so there may be a kit for that. You would maybe want to step up to the next higher weight capacity bag there too, due to the extra weight of the commercial chassis.
Be careful and do a lot of research though, especially on the weight capacity of bags. Bags are commonly referred to as 2500# or 2600# bags, and people think this is the weight capacity of the bag. Sometimes it is, or is close, but not always. If you're designing the system on your own, make sure you find out the true weight carrying capacity of the bags, don't just go by the part number. Most bag manufacturers have this info available if you do a little digging.
Originally posted by R U INJRD View Post... If you have leaf springs, you remove all the leafs but one or two on each side, and the air bag replaces the load carrying capacity. The remaining leaf is used to locate the axle and keep it in place. I've been running it for 2 years with no problems.
-Just curious, cause this would save me a LOT of hassle on a car I don't care enough about to 4-link.
ps. Creepy - I like em low too.
Originally posted by hearseboy View PostI have gone in favor of 4-link rear suspension, in the past. Have you guys had any issue with rear sway or shift when running just the single leaf? Any sign that the spring or shackles are fatiguing?
Also shouldnt be any more stress on the spring or shackles, the load there should be the same as well
You should be fine with mono leafs and even if it did have a little side to side you could always add a pan hard bar to it. 4 link is by far the best way to go normally, but to get one to fit in one of these, you have to cut the crap out of it, lol. I run a 2 link with a pan hard bar in mine, and while I was in there, I did 4 wheel disk brakes and an 8" narrower rear end to get 10" wide wheels to tuck all around.
