Maybe I'm not referring to it by the right name but its on the front pass side of the carb and has a small tube going to the carb close to where the fuel line connects and looks very similar to this
With the exception mine is partially metal. Inside is a spring and rubber gasket/seal that appears to be like a flexible boot. Mine is cracked on the plastic side. When I held it closed the car started right up.
Its purpose is to lock out the rear barrels until the engine is warmed up a little, and to dampen the secondary air valves.
