Hello all,
On my 64 my coil only gets power while the starter is cranking.
I know the coil only sees a full 12 volts while the starter is turning over the car. Once the car is running, the voltage is reduced. But how much?
According to the repair manual the power wire itself provides the resistance. That wire must be damaged somewhere as it has no voltage to it anymore.
I'll probably just run a fresh wire instead of trying to chase the original one through the back of the dash, but I'm sure I'll need some sort of resistor. Any ideas?
Thx
Thx
