1970 Lower Ball Joints?
  • 1970 Lower Ball Joints?
    My right front is got a case of the wiggles at low speed. Check and found the lower ball joint has too much play. Are these pressed in the control arm? I see I can buy replacement BJ but it doesn't show it as a replacement part in my service manual. It's a Caddy by the way.
    Yes they press in. If you pull the arm a local shop should press it for not too much. If your in socal/la Id press it for nothing. Also goes to any others on the board if your local and need press work give me a holler.
