I have ?'s that desperatly need answered
    Dwayne is right on the money with fuel.
    If I remember, 1974 still had a points distributor. Breakerless upgrade is worth every penny.
      1974 was the first year for HEI, but not all had it some still had points. I was changing my points every year on my 73 and finally got rid of them and haven't had a problem.
        yeah i just changed the oil on it today...... black as the ace of spades.... so nasty
        sad part is is that when i bled the brake lines they were the same color....
          so how can i tell if i have "points" or an "HEI"
          still kinda new to that aspect of the vehicle
            so how can i tell if i have "points" or an "HEI"&nbsp; <br>still kinda new to that aspect of the vehicle<br>
              If it has an external coil and coil wire to the center of the distributor cap, it's points ignition. HEI (high energy ignition) has a much larger distributor cap with the coil IN the cap, held in with screws.
              • #22
                hmmm ok i will have to check that out in the morning i currently dont have any hood hinges on her so lifting the hood is a work out by itself
                • #23
                  ok new question time...... i have no air coming out of my vents except when its all the way over to the right on the window defroster i believe. is that just a bad vacuum line or is there more problems under the dash i should worry about
