would these wheels fit?
  • would these wheels fit?
    Helped a friend haul in a dead 1999 Caddy Deville today, and it has nice 16 inch factory aluminum wheels on it, My question is, would these fit on my '75 Caddy limo?
    Unfortunately not plausible. Someone correct me if I'm off base here.
    '96 Fleetwood (D-body) was Cadillac's last rear wheel drive. '99 DeVille (C-body) is front wheel drive. Wheel offsets are vastly different.
      Correct Atti, all front-wheel-drives have a huge offset that puts the lug pattern almost flush with the outside of the rim. Truth be told, even the newer RWD cars & hearses have a huge positive offset where the majority of the depth is on the inside. Your '75 will be the large GM lug pattern (truck pattern commonly referred as) and that is 5 on 5" doubtful any FWD is this large pattern. Extremely doubtful these rims would clear your calipers even if they were by chance the right lug pattern.
        Most new Cadillac's are rear wheel drive, but the wheels are as you guys have said.
