Anyone got a wiring diagram for a windshield wiper motor on a 64? im tryin to trouble shoot why mines not working, want to put power right to the motor with my powerprobe to make sure its not a bad motor or ground and go from there
64 mm wiper motor
Your gonna need to get a 64 Cadillac service manual. Its worth its weight in gold. Disconnect the linkage on top of the wiper motor, cause I have had 2 cars that had the wiper transmission linkage froze up, and have a good motor. The center of the 3 terminals is the hot wire. Connect an external ground to the wiper motor frame. Connect a hot wire to the center terminal, connect a ground wire to the 1 & 3 terminals. The # 1 terminal is on top. You should get the low speed with all the wires hooked up. Remove the ground from the #3, and you will get the hi speed.
Originally posted by pyro View PostYour gonna need to get a 64 Cadillac service manual. Its worth its weight in gold. Disconnect the linkage on top of the wiper motor, cause I have had 2 cars that had the wiper transmission linkage froze up, and have a good motor. The center of the 3 terminals is the hot wire. Connect an external ground to the wiper motor frame. Connect a hot wire to the center terminal, connect a ground wire to the 1 & 3 terminals. The # 1 terminal is on top. You should get the low speed with all the wires hooked up. Remove the ground from the #3, and you will get the hi speed.
