Need a '72 rear wheel bearing seal
  • Need a '72 rear wheel bearing seal
    Anyone know where I can find a pair? It's for my '72 commercial chassis Cadillac ambulance. I believe '72 to '78 will fit. Thank you. Jim
    call usa parts supply 703 335 1935
    its now a bearing and seal all one part 1970 - 76 caddy commercial chassis
    139.95 not cheep but trust me i looked talked and looked some more till i found these guys .... no one makes the seal .. found a place that will make one for 1000.00 .......no kidding........
    no one makes the seal anymore i talked with people from CR.seals skf.. nat seal... etc its not made.....
    here are the #s that might help you find out they no longer make them.
    axle seal
    gm # 1493724 ***** not showing in the computers gm has anywhere....
    skf # 20900 **** stoped making 10 years ago
    the seal dimensions are
    2.086 ID
    3.171 OD
    with .376
    rear end # 14 1654
    ofd3
    312
    BD
    the bearings alone you can still get from napa etc
    but what good is a bearing with no seal ?????????????
      Check this Guy,
      Antique Auto Supply (817) 275-2381
      Also,
      Have you checked truck axle seals?
      Not the gm number
      but the seal dimensions cross reference measurements
      Sometimes,
      maybe?
      Might be worth a look...
        the only thing close was the international harvester scout
        same rear end but the axles were different somehow or something like that
        i spent weeks and weeks looking a few years ago
          I called USA Parts Supply, compared measurements and it seems like this is what I've been looking for! I ordered two and I'll let you know if they fit in a few days. Thank you! Jim
