Here are some pictures of my engine compartment from the time I removed the hood to current.
I have cleaned all the road grease off of & out of the engine compartment, frame, firewall, etc. Painted the whole area minus the fenders & fan shroud. The fenders will polish out & the fan shroud will get cleaned & painted once the electric fan is securely & properly mounted.
I removed the AC box located on the passenger side of the firewall & I'm currently fabricating a box to connect the hole in the firewall to the blower so my heater will work.
I've also redone some of the wiring harnass as well as fix some of those small things you can't get to while the engine is in there, like the windshield washer squiter motor & relocate the wires away from the engines heat.
