Originally posted by kaptinkaos
View Post
Big Evil, here is my progress
I think you should go a different direction. You obviously have a big enough radiator.
I would spend the $200 and install a large engine oil cooler in front of that rad. Many people don't realize how much engine oil aides in cooling the motor. I bet that will make the difference.
I would offer to do the hood for ya but you are quite a distance away. I did what Bigevil is describing to put the Formula scoops on my '68 Bonneville hearse. I hate the original A/C box that GM put on their old cars. I iwll be removing it from the '68. Yours is looking good with it removed. Are you planning on putting an aftermarket A/C unit back in or leaving it heat only?Originally posted by BIGEVIL View PostA round hole just big enough for the air cleaner should keep the strength of the hood in tact. I haven't seen a steel cowl "add-on" just fiberglass. I suppose you could buy a cheap cowl hood from "godfathers" that fit a whatever and cut the cowl portion off of it.
__________________
watch movies online
