Hey guys and gals, Does the light that some hearses have on top come off? And how do you remove it?
Light on top
Had a couple of those (with lights on top) over the years...the older ones were usually a single huge bolt with a nut on bottom holding it on with a metal contact that supplied power to the light (at least that was the way it was on the '70 Superior Combination) while the last one (a '94 Eagle) was held in place with 3 bolts and a power supply line through a (fourth) central hole.
