Also thinking about limited slip.
  • Also thinking about limited slip.
    If anybody has ever been around me or my car when I can do a burnout, I will most certainly do one (and with a new trans and fuel system, this shouldn't be an issue). I'm tired of the one wheel peel though and want to get a limited slip going.
    Does anybody have any idea where to begin? I'm pretty sure I'll need axles and a carrier, plus ring and worm - would it be easier/cheaper to just swap in a 9" or a Dana 60? Is it worth building a CC rear end?
    The old Chrysler 8 3/4 is a great inexpensive rear end for up to 600 ftlbs
    Easy to find, cheaper parts than a 9"
    Some off-road shops might be able to point you in a good direction also.
    4x4's certainly need LSD also
      The most durable is a 9" Ford but they can get expensive setting up one with a "Detroit Locker" setup. It only disengages when turning... unlike a spool. Don't let anyone talk you into a spool Chris. They're cheap BUT they lock the axles together permanently. Awesome in a wild pro-street but terrible for a 6,000# hearse with stock axles!
        Good call on the spool - I drove a buddy's car that had one in it and vowed I would never do it again.
