...that the torque converter won't seat all the way in?
I get the first drop, which I assume is the notches on the main outer shaft, then I hear it drop into the stator sleeve but the pump shaft (with the fine pitch teeth) doesn't seen to want to drop in at all. Trans is still under the car (I don't want to take the exhaust off), but I can't seem to get it no matter how much I spin and shove and cuss.
Why do I think it's not seated?
The converter feels wobbly in there and not a firm hold like you'd expect, plus there is exactly 1" from the face of the bellhousing to the mounting pad of the converter, but I believe it should be 1 3/16".
Any guidance on this one would be mighty helpful.
Chris
Chris
