so for a while now i've had this annoying leak under the dash that i couldn't figure out. water would magically appear, usually *under* the floor mat. i couldn't figure out how that happened.
well today i set out to fix it. this is what i discovered:
Here is what the leak looks like:
Here is where the leak was coming from. it's a hole next to the fuse box. i don't know if there was supposed to be a bolt in this hole or not, but water was dripping out of here at a pretty good rate.
so i found a clothes hanger to poke through the hole...
to see where it came out. this is where the hole comes out in the engine compartment. funny how such a little hole caused this massive leak. needless to say it's been plugged.
has anyone else had a similar leak?
