I've done it. You just have to make sure that you drill straight through the center. I work with a pilot hole and go progessively up to a size smaller than the bolt hole, then take the remains of the bolt out in shavings, with cutting oil and a tap. If the drill bit goes crooked, though, you are royally screwed, no pun intended.
